Re: Re: Re: 300 U hyd.
Posted by LanceM on December 12, 2001 at 03:01:19 from (199.46.198.231):
In Reply to: Re: Re: 300 U hyd. posted by big fred - Lance, is this the plug you mean? on December 11, 2001 at 21:15:38:
Good Pics,
Yes the first one, the little one is the real drain plug, the power steering connection is where I drained mine. I see that you have the brazed up lines on yours too, mine still leak a bit and need to be redone. While you have it drained you might as well pull it apart and check the strainer and clean out the bottom of the reservior, a lot of crud will collect there over the years. Even after draining there will still be about 1/2 a quart of oil in the bottom of the reservior.
Lance
Post A Followup
: Re: Re: Re: Re: 300 U hyd.
