Re: Can Generator be 6V OR 12V
Posted by Bob M on December 12, 2001 at 11:55:49 from (165.170.128.65):
In Reply to: Can Generator be 6V OR 12V posted by John on December 12, 2001 at 09:59:13:
The starter shop is right - you can't simply stick a generator on a stand and determine the design voltage. However since your tractor has 12 volt lights, chances are pretty good the charging system has been converted 12 volts. Here's how I'd verify:
1 - Get the all the wiring to the generator, voltage reg and ammeter connected correctly.
2 - Drop in and connect a charged 12 volt battery. At this point it doesn't matter which battery post you connect the grounded battery cable to.
3 - Turn on the lights and look at the ammeter - it should show a few amps of discharge. If it shows charge, swap the two cable connections at the battery.
4 - Now polarize the generator (use a short jumper wire to momentarily connect the BAT and GEN terminals at the voltage reg)
5 - Finally start the tractor, run it at 1/2 speed or higher and check the ammeter. If it indicates charge, you're all set! If it does not....
6 - With the motor running at about 1/2 max RPM, jumper the regulator FLD terminal to a good ground, then jumper the regulator GEN and BAT terminals together. If the ammeter now shows charge, get a new 12 volt regulator. If it still does not charge, you've either got a 6 volt generator or the generator itself is no good.
Hope this helps....
Post A Followup
: Re: Re: Can Generator be 6V OR 12V
