Re: Case IH 2150 Red Paint Problems
Posted by Steven@nd on December 13, 2001 at 12:31:16 from (165.234.130.119):
In Reply to: Case IH 2150 Red Paint Problems posted by George from Alberta on December 13, 2001 at 12:07:58:
Have done lots of spray can painting. Is the metal properly prepped? Sanded and primed? Did you shake the can really good? HOW COLD IS IT WHERE YOU ARE PAINTING? It should be at least 65 degrees F if you want to do a decent job.
Steven
Post A Followup
: Re: Re: Case IH 2150 Red Paint Problems
