Re: Case IH 2150 Red Paint Problems
Posted by Red Dave on December 13, 2001 at 12:42:30 from (208.165.46.34):
In Reply to: Case IH 2150 Red Paint Problems posted by George from Alberta on December 13, 2001 at 12:07:58:
Check the posts below and follow their suggestions. If you do and still don't get results, your can may be bad for some reason.
I have used their spray cans quite a few times with good results.
Post A Followup
: Re: Re: Case IH 2150 Red Paint Problems
