Re: TSC SPOOL VALVE
Posted by gene b on December 14, 2001 at 04:31:19 from (63.15.137.54):
In Reply to: TSC SPOOL VALVE posted by budaa on December 13, 2001 at 14:10:49:
are you sure you bought the right spool you need a four spool for two way and two spool for one-way hook into the belley pump outlet thru the 4-spool then back to the resivour and like you said pull the lift-all lever back and lock it and it will work better check the valve you bought
Post A Followup
: Re: Re: TSC SPOOL VALVE
