Re: TSC SPOOL VALVE
Posted by Haas on December 14, 2001 at 05:56:02 from (129.37.117.138):
In Reply to: TSC SPOOL VALVE posted by budaa on December 13, 2001 at 14:10:49:
I think I was the one that gave you that catalog number. The catalog says the valve is convertable for single or double acting. The valve has to be set for double acting to give pressure in both directions. Have you read the instructions that must have come with the valve?? There should be 4 ports on the valve. One for the pressure supply, one for the return to the reservoir, and two for the cylinder. The instruction sheet should tell you how to set up for double acting.
Post A Followup
: Re: Re: TSC SPOOL VALVE
