Re: Re: Farmall 400 wiring
Posted by Steve on December 15, 2001 at 12:03:34 from (198.173.144.125):
In Reply to: Re: Farmall 400 wiring posted by Dann on December 15, 2001 at 00:20:24:
Dann, it still has 12volt gen, the wiring is cracked . I would like repalce the wiring from the generator to the solinoid and regulator, then to the swtitch. I need a list or diagram of the wiring so I get all of the wiring hooked up right the first time and wont ruin a new regulator. How hard would it be to put a regular 12 volt altenator on it, and how will the wiring be changed.
Steve
Post A Followup
: Re: Re: Re: Farmall 400 wiring
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
