Re: Re: Governor Problem Solved !!!
Posted by EZHangin on December 17, 2001 at 09:33:45 from (216.211.32.2):
In Reply to: Re: Governor Problem Solved !!! posted by Bob M on December 17, 2001 at 07:23:52:
So far , all I can tell is that there seems to be no charge coming from alt.
Battery voltage while running is 12.15vdc, of course drops lower to 12.07 when lights are turned on. My warning light will not go out as you know. My only option now is to pull it and get it checked. Unless there is some way to "excite" it, if that is possible.
If I keep running it like this it will surely die in an inconvenient location.
Post A Followup
: Re: Re: Re: Governor Problem Solved !!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
