Re: M Fender mounting hole depth?
Posted by dennis on December 17, 2001 at 12:05:47 from (216.228.46.209):
In Reply to: M Fender mounting hole depth? posted by Zim on December 16, 2001 at 15:11:40:
The holes are blind. If the casting has not caused a problem it probably will never be a problem. When I restore tractors I always clean and tap the holes and put corks in the holes. After sanding flat and painting they look good and will never fill back with dirt. I always laugh when I do this because they look like twisted off bolts. Won't someone be surprised (and happy) to find they are only cork.
Post A Followup
: Re: Re: M Fender mounting hole depth?
