Re: Farmall H stuck in gear(s)?
Posted by Dave_Id on December 24, 2001 at 11:39:29 from (63.20.49.223):
In Reply to: Farmall H stuck in gear(s)? posted by Chuck Puett on December 24, 2001 at 11:05:41:
Bob M is probably right. You'll need to rem. pin, spring and convex flange on your gear shift lever. Then you can see what you have. This will be a good time to check for wear on your shifter pawls. If you have too much, you may want to build up with a hard weld and refit.
Post A Followup
: Re: Re: Farmall H stuck in gear(s)?
