Re: Belly pump Removal on SM
Posted by Belly Pump !!! on December 27, 2001 at 15:24:47 from (209.240.222.132):
In Reply to: Belly pump Removal on SM posted by PAWNEE on December 27, 2001 at 10:59:25:
John d explained it pretty good but I have found that if you loosen the fill pipe but leave it in when you drop the pump if it happens to fall off jack or what your using the fill pipe is a little safety device to fall back on.!! I use a regular floor jack and made a brkt that pins to the bottom of the pump and bolts to jack.
Post A Followup
: Re: Re: Belly pump Removal on SM
