Re: Got a problem on my 49M
Posted by jal-SD on December 28, 2001 at 13:06:51 from (63.65.239.8):
In Reply to: Got a problem on my 49M posted by Jack on December 28, 2001 at 11:03:14:
Check the gaskets between carb & intake & intake & head. Sounds like it may be drawing air into the combustion chamber from one of these places. You can check by spraying WD-40 in these areas when its running. If it runs better while spraying, chances are thats where the problem is. (Be careful when spraying WD-40, as it uses propane for propellant.)
Post A Followup
: Re: Re: Got a problem on my 49M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
