Re: Re: OK - I want everything in a tractor...
Posted by gibby on December 28, 2001 at 20:29:27 from (24.26.152.154):
In Reply to: Re: OK - I want everything in a tractor... posted by ron g on December 28, 2001 at 16:10:21:
HI Ron,
The genset I am buying is from Voltmaster. They have a new voltage regulator that is suppose to keep it in line Plus or minus .6%. Hopefully this is true. The guy that drilled my well used a 5kw generator to test pump the well, Hopefully it is able to handle it. I will check in the morning with the well driller. Thanks for the heads up.
Dave
Post A Followup
: Re: Re: Re: OK - I want everything in a tractor...
