Re: Got a problem on my 49M
Posted by setter on December 30, 2001 at 04:23:35 from (205.217.81.93):
In Reply to: Got a problem on my 49M posted by Jack on December 28, 2001 at 11:03:14:
I have the same problem with my 1951 H. I have rebuilt the carb and changed all the jets, adjusted screws, and used propane around the manifold to check for leks to no avail. I would be interested to know if and how you resolve this. It just doesn't seem like there could be much of anything else to check. Is the gap on the points a possibility or timing?
Post A Followup
: Re: Re: Got a problem on my 49M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
