Re: H problems
Posted by Dave_Id on December 30, 2001 at 09:37:47 from (63.20.49.148):
In Reply to: H problems posted by Dave Z on December 30, 2001 at 08:38:08:
My first guess it's out of time....Answer to the first question about leaking gas from the main jet. The packing is shot. Try to tighten the nut on the main jet, this will compact the packing some. You must have a bad needle valve, sounds like gas is running thru and filling up the air cleaner hose, not allowing air to come in for starting. Remove hose to air cleaner temporarily to see if this is what's happening. Check float on carb, make sure it doesn't have a hole in it, thus making it useless to shut off gas. First thing though is to time the mag according to specs in operators manual, don't try to rotate to where it's running best, that won't help starting.
Post A Followup
: Re: Re: H problems
