Re: Re: 400 stuck in two gears
Posted by Doug Stevenson on December 31, 2001 at 16:15:28 from (206.9.239.132):
In Reply to: Re: 400 stuck in two gears posted by Carp on December 31, 2001 at 16:00:16:
take the shift lever out of the trans by removing the two frost plugs (with a chisel or screwdriver)and use a rod to line up the slots in your shifter rails so there strait across from eachother which would be neutral the end of the shiftlever probally needs to be built up with weld
Post A Followup
: Re: Re: Re: 400 stuck in two gears
