Re: 230 tranny, how to get the shaft out?
Posted by the tractor vet on December 31, 2001 at 19:33:31 from (216.196.13.44):
In Reply to: 230 tranny, how to get the shaft out? posted by Drizler on December 31, 2001 at 19:18:26:
You are going to have to split the tractor to fix the transmission and myself i would fix the axel before i split the tractor , you will have to remove the deck and it will make getting the bull gear off easyer you will have to remove the axel and houseing from the tractor and you will have to press the bearing off the axel and press it back on.
Post A Followup
: Re: Re: 230 tranny, how to get the shaft out?
