Re: 1955 300 utility value
Posted by big fred on January 02, 2002 at 20:45:06 from (208.51.245.51):
In Reply to: 1955 300 utility value posted by chris on January 02, 2002 at 19:47:38:
The power steering unit will have a couple of hydraulic lines running to it. It will also have a short cylinder (looks a lot like a oil filter canister) sticking aft from the rightside of the steering arm housing, kind of pointing at the battery if the battery is still in place.
In the condition you describe, I would say it probably isn't worth much, maybe $500 if you planned on parting it and knew somebody needing parts, $300 tops if you planned on restoring it. The thing that would scare me off would be the froze-up tranny, I think. On the other hand, if it had a power steering unit in good condition, they are scarcer than hen's teeth, and you could probably get close to a grand for just that part of it if you were parting it.
Post A Followup
: Re: Re: 1955 300 utility value
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
