Re: substituting hydraulic fluid
Posted by gene b on January 03, 2002 at 04:25:20 from (63.25.167.128):
In Reply to: substituting hydraulic fluid posted by James (MO) on January 02, 2002 at 19:20:57:
sounds like the journal is bad on the pump shaft worn where the seal goes you need to put a speedy sleeve on the shaft easy to do go to a parts place if they dont know about one go some where else these things do work they are thin and will go over the end of the shaft and will restore the journal by getting rid of the worn place where the seal sets
Post A Followup
: Re: Re: substituting hydraulic fluid
