Re: substituting hydraulic fluid
Posted by Haas on January 03, 2002 at 07:19:16 from (129.37.117.251):
In Reply to: substituting hydraulic fluid posted by James (MO) on January 02, 2002 at 19:20:57:
Heavier oil won't stop the leak, or even slow it down much.
Post A Followup
: Re: Re: substituting hydraulic fluid
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
