Re: Re: Need opinions on overhaul kits....
Posted by Steven@nd on January 05, 2002 at 19:26:40 from (12.15.56.30):
In Reply to: Re: Need opinions on overhaul kits.... posted by Larry on January 05, 2002 at 19:15:17:
There was just quite a bit of noticeable slack in the rod bearings, and after taking them apart I see that they are pitted and a couple of them have some scratches I don't like. Pits are probably the result of short running times and condensation (water) in the oil. The water turns to acid and eats bearings for lunch.
Also the fact that it has been sitting 25 years down by the river doesn't help. I believe the oil pump should be ok. What's inside of there to fix anyways? Never really gone this deep into an IH engine, usually just take heads off and have valves ground.
Steven
Post A Followup
: Re: Re: Re: Need opinions on overhaul kits....
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
