Re: Re: Re: Need opinions on overhaul kits....
Posted by Zonie on January 06, 2002 at 08:14:38 from (152.163.201.84):
In Reply to: Re: Re: Need opinions on overhaul kits.... posted by Steven@nd on January 05, 2002 at 19:26:40:
I checked my H oil pump and found the bottom plate had grooves worn in it where the gears run aginst it. I used some 400 grit sand paper on a very flat surface to surface the plate till the grooves were gone. My oil pressure is great now!
Post A Followup
: Re: Re: Re: Re: Need opinions on overhaul kits....
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
