checking the oil on a farmall c
Posted by jimmy on January 06, 2002 at 07:02:05 from (208.180.19.147):
as a new farmall c owner do you check the oil by turning the pitcock on the lower left hand side of the motor and adding oil until it runs out? Also do you use straight 30 wt oil? thanks
Post A Followup
: Re: checking the oil on a farmall c
