Re: Are you using multi grade oils?
Posted by brianh on January 08, 2002 at 12:29:30 from (152.163.201.209):
In Reply to: Are you using multi grade oils? posted by Jon with an M on January 08, 2002 at 09:40:47:
The instruction book for my MD calls for 10W oil thinned with kerosine or diesel fuel in cold weather. So, since the goal here is something thinner than 10W, I put 5W-30 in it in the wintertime. Good cold starting is important since I plow snow with it. Starts good and holds oil pressure good when it's hot, so I think its OK.
Post A Followup
: Re: Re: Are you using multi grade oils?
