Are you using multi grade oils?
Posted by Jon with an M on January 08, 2002 at 09:40:47 from (192.35.84.12):
I would like to hear from anyone who has switched to using multi grade oil in older tractors. What weight are you using. How long have you been running it. How hard do you run your tractor and have you experienced any oil related problems.
I have a 41' M and currently run straight HD 30 here in Maryland. I want to use my M to push snow and thought 10W 30 would be easier on it for those cold starts.
Thanks, Jon M.
Post A Followup
: Re: Are you using multi grade oils?
