Re: water in the oil
Posted by ScottyNY on January 08, 2002 at 18:24:34 from (128.59.6.48):
In Reply to: water in the oil posted by Mike on January 08, 2002 at 16:16:24:
Doesn't sound good, but it might be a relatively easy fix. Take a real close look(it might help to drain out what antifreeze is left and blow everything real dry and refill with water to get a good handle on exactly where the water is coming down from). Worst case is that the block, frozen or not, may have cracked across the bridge(s) between the sleeve(s). That's gonna call for some clever welding,though I've read a thread here recently where guys have fixed some minor cracks with silicone or other sealers. By all means check that out. The better case, and I sure hope this is the one, is what Old Dutch suggests--that for whatever reason the O-rings aren't sealing up well. You can try taking the rods off the crank and liftings each sleeve, soaping up the bottom part and reinstalling, but the better bet is to clean out the grooves real well, put in new O-rings and soap the sleeves before reinstalling them and putting things back together. A lot of work but low on parts cost (gaskets top and bottom and O-rings, maybe hoses). If the motor has been recently rebuilt as you think it might, that ought to do it. If the motor does need rebuilding, there's be no better time than when you have it that far apart anyway. Good luck and let us know how you make out!
Post A Followup
: Re: Re: water in the oil
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
