Re: Round bale spike on H
Posted by Zonie on January 09, 2002 at 19:41:03 from (152.163.204.61):
In Reply to: Round bale spike on H posted by Larry on January 09, 2002 at 19:32:28:
My H frontend was light with the extra heavy blade I built for it. I added water to the front tires and that helped alot.
You'll probably want to add a water antifreeze mixture depending on what part of the country you live in. It rarely gets more than a few degrees under freezing here in Arizona, that's why I just added water.It only adds 100lbs. or so but it helps alot.
Post A Followup
: Re: Re: Round bale spike on H
