Re: Exhaust lift
Posted by Carl Cummins on January 10, 2002 at 10:31:25 from (216.55.173.52):
In Reply to: Exhaust lift posted by Kurt on January 10, 2002 at 08:25:38:
Yes Red Dave is exactly correctly. I bought a one bottom 12" plow for my 1939 Model "A" and it came with a exhaust lift. I hear they can be quite difficult to mantain so I went back to the manual lift. Not too bad, my arm is still intact after 23 hours of plowing on 8 acres! You do need the correct rock shaft to hook it up properly. I still have the lift and maybe some day, try to use it.
Post A Followup
: Re: Re: Exhaust lift
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
