Re: Re: farmall 450d
Posted by farmallgod on January 12, 2002 at 07:19:28 from (152.121.255.254):
In Reply to: Re: farmall 450d posted by jmyt_47 on January 11, 2002 at 13:38:59:
It all depends on if your going to use the tractor or restore it. The MD and the 450 engine wise are almost identical,the 450 has a bigger piston and sleeve, if I was going to use the tractor i would probably go with the 450 it has more options either way parts are going to be expensive. As far as water in the oil Those tractors were known for blowing the head gaskets and rear main seals wen't pretty quick too.
Post A Followup
: Re: Re: Re: farmall 450d
