H rods and main bearing clearances.
Posted by Mike ISW on January 12, 2002 at 11:35:11 from (64.12.102.48):
Starting to reassemble my "H". I checked rod and main journals with dial caliper and knew going in that my clearances were a bit on the high side. Now I plasti-gaged rods and mains in engine. All are .004"-.005". Manual calls for .002"-.003". I realize I'll lose some oil pressure. How much? Do you think at the higher clearances they'll knock and cause other problems? This tractor will not be used for heavy work. Just putting together for show/hobby. Thank You
Post A Followup
: Re: H rods and main bearing clearances.
