Re: H rods and main bearing clearances.
Posted by Larry on January 12, 2002 at 16:13:20 from (63.106.164.102):
In Reply to: H rods and main bearing clearances. posted by Mike ISW on January 12, 2002 at 11:35:11:
Mike - That's alot of play on the rods and bearings..you could end up spending alot more money if the bearings spin or you lose oil pressure and toast everything. I believe you can special order bearings in those size ranges. Does the crank mic true or does it need to be turned?
Post A Followup
: Re: Re: H rods and main bearing clearances.
