Re: Re: high range on H
Posted by Dick Davis on January 14, 2002 at 04:54:13 from (205.188.192.33):
In Reply to: Re: high range on H posted by Zonie on January 13, 2002 at 21:58:04:
Aftermarket M&W was a selectable gearing added to the transmission of H's, M's and probably many other tractors. The gearing markedly increased R,1,2,3,4. I believe the new speeds were between old 4th and 5th. Normal 5th ("Roadgear" my Dad always called it) was not effected. Which is a good thing, don't believe I would want to be on an H in 5th overdrive!
Does a Heisler work the same way?
Olaf does your cable effect R,1,2,3,& 4 or just 5th? If it only affects 5th maybe someone has added gearing to decrease the 1:1 ratio of normal 5th. If so, I'll bet it is a very uncommon (dangerous?)alteration. Tell us more.
Post A Followup
: Re: Re: Re: high range on H
