Re: Re: Re: Re: Spark Plugs 6 V verses 12V
Posted by Bob/Maine on January 18, 2002 at 04:58:43 from (65.90.98.9):
In Reply to: Re: Re: Re: Spark Plugs 6 V verses 12V posted by Larry on January 17, 2002 at 23:43:19:
Hi again, OK I am guilty of not knowing what I am talking about. Or at least explaining myself. With a 6V system you have a coil that gives less voltage, may be around 30,000 volts. A 12V system you have a coil that is around 45,000 volts. The spark plug gap on a 6V system would be around .025 as on a 12V system the gap would be around .035. Thanks for your comments! I had a good laugh when I read what I had tried to explain.
Bob
Post A Followup
: Re: Re: Re: Re: Re: Spark Plugs 6 V verses 12V
