Re: Super A Distributor Question
Posted by ScottyNY on January 18, 2002 at 06:10:09 from (128.59.123.240):
In Reply to: Super A Distributor Question posted by Keith F. on January 18, 2002 at 04:15:18:
The front end, which runs off the governor, gets its oil from the crankcase. From there, heading back toward the rotor, there should be two zerks, though the books suggest that there may be set screws that need to be replaced with zerks. One of them won't take much grease at all--one stroke of the gun usually shoots right out the vent on the back side. The other should only be given a couple of strokes of grease periodically.
Post A Followup
: Re: Re: Super A Distributor Question
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
