Re: How High Can a 6 Volt Generator Be Turned Up?
Posted by FC on January 18, 2002 at 07:47:28 from (208.14.16.15):
In Reply to: How High Can a 6 Volt Generator Be Turned Up? posted by cheg on January 18, 2002 at 07:30:17:
Don't forget about the coil, and use either a 12 volt coil or put in a ballast. There was a post a while back which someone said they used the old generator and just switched to a 12 volt regulator and it worked great. Makes sense since the primary function of the "voltage regulator" is to regulate the voltage. You might search the archived discussions for this info.
Post A Followup
: Re: Re: How High Can a 6 Volt Generator Be Turned Up?
