Re: Re: Sticky Valve(s) on 1944 A
Posted by EZ on January 18, 2002 at 14:25:57 from (216.211.32.2):
In Reply to: Re: Sticky Valve(s) on 1944 A posted by scotty on January 18, 2002 at 06:40:28:
I've read and been told that when engine heats up
to temp and starts to die out, you could have a valve that is not closing all the way causing missing. I will try checking the coil though. It's 10 below zero outdoors here now, so won't be tinkering too much outside the shop. The A also has had the gas tank replaced and there is some dirt that I have to clean out of glass bowl every now and again.
Post A Followup
: Re: Re: Re: Sticky Valve(s) on 1944 A
