Re: Re: How High Can a 6 Volt Generator Be Turned Up?
Posted by steve on January 18, 2002 at 19:23:24 from (204.246.222.134):
In Reply to: Re: How High Can a 6 Volt Generator Be Turned Up? posted by Irv on January 18, 2002 at 17:48:41:
IRV- the 6 volt generator has the "A" terminal negative and the "F" termnal positive ground. Did you reverse these at the regulator to get it to charge negative ground, or did you hook G to G and F to F. Did polorazing take car of it?? I never heard of doing this, just curious.
Post A Followup
: Re: Re: Re: How High Can a 6 Volt Generator Be Turned Up?
