Re: How High Can a 6 Volt Generator Be Turned Up?
Posted by Irv on January 18, 2002 at 17:48:41 from (172.130.22.234):
In Reply to: How High Can a 6 Volt Generator Be Turned Up? posted by cheg on January 18, 2002 at 07:30:17:
I posted my conversion awhile back. Some might disagree, but I have a few hours on it, and it statrts great. The 6V was a pia. I used a 12 volt regulator, polarized per inc. instructions, switched wires at the starter switch, 12V bulbs, new battery, now a neg. ground, just like a car. I have a mag. so no coil. Good luck, it isn't too hard and you can always play around some more. Irv
Post A Followup
: Re: Re: How High Can a 6 Volt Generator Be Turned Up?
