Re: TD6 Fuel Filter Woes
Posted by Red Rider on January 21, 2002 at 20:45:28 from (63.44.140.74):
In Reply to: TD6 Fuel Filter Woes posted by Rik from Paso on January 20, 2002 at 21:10:17:
In 1955 after Serial 15401 IH diesels used the same fuel filters for both auxiliary and final. The filter canister bolts are the same and you don't need the sleeve adapter that was required for the smaller filter. If you don't have a filter and water separater on your fuel tank you should put one on it.
Post A Followup
: Re: Re: TD6 Fuel Filter Woes
