Re: Mag works! wiring question
Posted by Bob M on January 23, 2002 at 12:57:32 from (66.66.72.246):
In Reply to: Mag works! wiring question posted by Jon with an M on January 23, 2002 at 12:29:16:
Jon - You still need that switch on the #1 wire, and remember to open it when you shut down the motor. Otherwise the battery slowly discharge thru the alternator when the motor is stopped.
Post A Followup
: Re: Re: Mag works! wiring question
