Re: Engine Assembly...What do you guys do?
Posted by Deere Puller on January 23, 2002 at 16:20:08 from (209.105.184.61):
In Reply to: Engine Assembly...What do you guys do? posted by JDM on January 23, 2002 at 14:31:55:
I presume that you're not using the Permatex product? That item is made for sealing gaskets, etc. & I do use Hi-Tack for nearly all gasket surfaces. For engine parts, I typically use a cam & lifter lube on the cam / lifters and engine / bearing lube on the crank & all other parts that need lubrication prior to oil pressure. Cylinder walls get a lite coat of SAE 30 if it will run soon after assembly, a coat of assembly lube if it will sit around for awhile.
Post A Followup
: Re: Re: Engine Assembly...What do you guys do?
