Re: Rebuilt M Engine Won't Start
Posted by twopop on January 23, 2002 at 17:21:04 from (65.197.92.88):
In Reply to: Rebuilt M Engine Won't Start posted by John on January 23, 2002 at 17:08:22:
take the # 1 spark plug out and put your thumb over the hole. tap the starter until your thumb is pushed off the hole by compression,then take the dist.cap off and see which plug wire it is pointed at.if it is pointed to # 1 then with the dist.cap off tap the starter again and see which way the rotor turns,from your wire clock discription the rotor would be turning counter clock wise
Post A Followup
: Re: Re: Rebuilt M Engine Won't Start
