Farmall Tractors Discussion Board
Re: Super MTA oil and block drain
Posted by Clinton E. Hofstetter on March 18, 1999 at 11:36:48:
In Reply to: Super MTA oil and block drain posted by Randy on March 18, 1999 at 10:28:20:
I think the Super MTA uses the same block as the MD or nearly the same. The block water drain is on the left side (injector pump side) above the injector pump, about in the middle. I thnk the owners manual calls for 85W oil in the transmission. There may be two drains, on on the transmission and one just behind the bell housing. It may all drain from the transmission. For the engine there should be a dipstick to check the oil. The MD has one and I can't imagine that the Super MTA would not.
Post a Followup
: Re: Re: Super MTA oil and block drain
