Farmall Tractors Discussion Board
Re: Re: Super MTA oil and block drain
Posted by Don Summers on March 18, 1999 at 15:14:12:
In Reply to: Re: Super MTA oil and block drain posted by Clinton E. Hofstetter on March 18, 1999 at 11:36:48:
The block drain is on the left side of the engine behind the carburator. The engine holds 10 qts. of oil when the filter is changed too. The engine oil is checked at the petcocks on the right side of the oil pan. Pour it in until runs out the top cock when it is open. Only use Case-IH HY-Trans fluid in the transmission, rear end and hydraulic system. The rear end drains right above the drawbar, there is another plug under the transmission, maybe 2. Hope this helps you, I have a Super MTA gas, so I know of what I speak.
Post a Followup
: Re: Re: Re: Super MTA oil and block drain
