Farmall Tractors Discussion Board
Re: F-12 runs bad
Posted by Paul Fox on March 19, 1999 at 15:46:13:
In Reply to: F-12 runs bad posted by Erick S. on March 19, 1999 at 07:41:20:
My first thought is that it sounds like a fuel problem. Have you made any recent changes that would affect fuel flow? Are you seeing plenty of fuel motion in the glass bowl on the fuel pump? Good clean fuel? Any chance that condensation has gotten water in your fuel? Sometimes frequent changes in temperature will do that. You might try some dry-gas. Also, have a close look at the fuel in the fuel bowl on the pump. Water will "glob up" and be pretty obvious. My tank was as clean as a hound's tooth in August, and now, with the winter temps all over the chart, I'm getting rust flakes in the fuel bowl, have to dump it and clean it out every 3 or 4 hours of running time. Hope some of this helps.
Post a Followup
: Re: Re: F-12 runs bad
