706 wiring?
Posted by David C. Foreman on March 16, 2009 at 19:57:19 from (216.93.97.207):
I have removed my generator in the winter to work on the governor and carb. Putting it back together I have a good sized wire coming from the dash area through a hanger on the front of carb and is long enough to reach generator, but for the life of me I don't remember where it should fasten????? Generator anchor bolt like a ground or to one of the two little generator stems which I have the little wires hooked to, or something else around the carb??? HELP!
