Farmall Tractors Discussion Board
Re: F20 raditor cap
Posted by Bob on March 23, 1999 at 04:58:24:
In Reply to: F20 raditor cap posted by Dan on March 22, 1999 at 17:07:26:
Dan, Read your problem with the radiator cap and just wanted to say if you need to get another one I make them. Problem is, as I write this I am getting ready to go vacation for two weeks so if you are still in need get back with me after April 10. I have 3 tractor that needed them so I made a pattern and cast the cap in aluminum and the bolt in brass. I still used the steel bar that was on the original. The cap looks like the original just a little thicker on the cross section.
Good luck, Bob
Post a Followup
: Re: Re: F20 raditor cap
