Farmall Tractors Discussion Board
Re: H light switch w/12V
Posted by Phil Auten on March 23, 1999 at 17:07:51:
In Reply to: H light switch w/12V posted by john on March 23, 1999 at 13:55:59:
John,
The resistor will be fine. The current required for the 12V lights should be about half of the 6V lights. Just be sure to change the bulbs out or replace the lights altogether. The 6V bulbs won't last more than a few seconds on 12V. Bob is probably right about the dimming effect. You may have to change the resistor to a larger value one to get the dimming effect back to normal. Try one with 2X the Ohms of the original one to start with.
Phil
Post a Followup
: Re: Re: H light switch w/12V
