Posted by tesmith66 on March 17, 2009 at 03:40:25 from (130.76.96.14):
Hi All.
Do I have to drain the transmission before I remove the PTO unit? The manual simply says "remove unit". Also, is there a rebuild kit available for these (clutch type)? It is slipping under load and is adjusted so tight it drags when disengaged. I imagine it needs new friction plates. What are the common failure modes on these beasts and how poor will I be after the dealer gets finished with me? Is there an aftermarket parts source?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
