Re: 340U IPTO questions
Posted by Mark W. on March 17, 2009 at 04:37:38 from (64.83.132.2):
In Reply to: 340U IPTO questions posted by tesmith66 on March 17, 2009 at 03:40:25:
Had to completely rebuild mine last year. If you can angle the front
of the tractor downhill you will limit the amount of fluid lost. You
will lose some as you are opening the back of the transmission.
Unhook linkage and 4 bolts and slide straight back. Pretty heavy.
There is an o-ring between the unit and casing. I had over $750 in
parts rebuilding mine last year. Be careful, it is heavy.
